My timing gear housing broke
Disconnect door buzzer!
banks stinger kit for 24 valve
Yesterday, as I was stopping at a traffic light, I heard a pop from under the hood.
I pulled through the intersection and pulled over. I left the engine running and raised the hood. There was a hole in the gear housing just above the fly wheel with oil running out. I ran to the cab and shut the engine off. I only lost about a cup of oil but I am sick. The truck is at the dealership. I saw another B5. 9 with the gear housing broken at exactly the same place at a Cummins Repair Center near here.
1995 Ram 2500 4x4 3. 54 (sick owner)
1995 Ram 2500 4x4 3. 54 5 spd
I have seen this on two other trucks.
There is a pin that falls out and gets wedged in between the timing gear and cover and blows a hole through it.
All have been covered under warrantee.
Good luck
Ted Jannetty
Ted Jannetty, Owner President Jannetty Racing Enterprises Inc.
97 3500 4x4 club cab 5spd. JRE stage 3 power kit, JRE 4" exhaust
JRE 1/2 inch fuel system, Cummins 300 hp injectors, Prime loc,
Cummins chrome kit, US Gear 20% over drive, 3. 54 axle, 2 gauge
mount with 50 lb. boost gauge, BD exhaust brake.
