Details here: TDR Privileges
Truck info ?. I do not believe there is a fuse and it runs directly off the ECM. If there is a fuse someone added it. Is the pump in the standard location (mounted to the block) or did it get moved into the tank or otherwise relocated.
If you have a 2nd gen 24 valve with the in tank retrofit pump there will be an in-line fuse holder.The relay for that system should be mounted on the driver side usually tie wrapped in the general area of the firewall
