My truck won't get fuel
Passenger power mirror issue
Cranks over like normal. It's was gelled up yesterday, been in a heated garage and at this point I don't think it's gelled up anymore. It will crank over at normal soeed but won't start. I don't think it is getting fuekcbutndont know why or how .. i don't know what to do to fix it.
2004 ram 2500 cummins
24 valve 3rd gen
common rail
I just went through this. Did you change your fuel filter? If you havent, do so. Also, plug your block heater in for some time. It will help to thaw things out.
I had a fuel filter replaced about a week prior to this happening. And yes I plugged the block heater in a couple of hours ago
If that does not work, load the fuel filter with Diesel service "911", and add some to the tank, it should help thaw the Gel, and then add a bit of Anti Gel of your choice, to the tank, and drive it or top it off to mix it well, and get it in the system.
But warming the truck might do the job.
Not only might the week old filter be trashed but changing it again will show what’s in that fuel canister. Drain the canister into a clean pan. If there’s little or no fuel that drains out your lift pump might have given up.
