My truck!
Gen Light
Fuel Pressure
I guess I can finally say that my truck is up and running again.
I'm running with an H2E turbo and a marine cam.
These are just my opinions, but I wouldn't recommend either one.
The turbo is just too big for street use. Pulling is definately not an option anymore. You would think that the huge turbo would reduce EGT on the topend, but I honestly haven't seen it. It has the 17 cm housing not a tiny restrictive 12 or 14. I pegged the digital gauge at 1747° by 50 mph from a standing start. This is the first turbo that doesn't clean up smoke. The other two turbos I've tried would smoke down low, but the smoke would clean up once the turbo spooled. This thing smokes anytime the boost is above 20. As you add fuel to make more boost it just smokes more. I have enough fuel to push it to 46 psi and the smoke never clears up. It's just WAY to big to be used as a single turbo IMO.
The cam is equally unimpressive or maybe it is the cause for making the H2E look so bad. I try to drive around without smoking out everyone around me. If I hold the throttle at a constant fueling rate, the truck will accelerate without smoke until 25-2600 rpm. After that the smoke begins to get thicker and thicker. It seems as if the cam doesn't breathe well above 2500 rpm.
These two modifications didn't increase power enough to be noticeable. It honestly might have lost power.
As far as airflow goes. I've got a fresh three angle valve job. Ported head from Piers. New pistons/rings. 4" exhaust. Marine cam. H2E turbo. And there's just not enough air getting into the motor to make any serious power.
My stock motor with 150,000 miles and only fueling modifications would walk away from this truck.
-Chris
camshaft
How do you think the engine will run with a hx40 or a b1. It seems hard to believe that the marine camshaft would make the engine smoke like that. Do the camshafts time the same? Are marine engines designed to run at a lower speed? Sounds like huge amount of fuel to smoke at 40 plus psi.
Chris I believe that Les Ewen installed a marine camshaft in his truck along with lower compression and I thought that it ran good, but trashed the automatic as it was a hot shot rig.
How ever I have no experince with the marine camshaft, I had thought that the engine was designed to run under a load and make a lot of torque. The marine engine has a lot of cooling though as the innercooler is air to water, or vice versa. Does the marine camshaft have the same lift. Thanks JImk
Maybe Don M will chime in here.
He told me a friend of his installed a marine cam and pistons and lost 65 HP. I don't know anything else, but I can tell you this setup is NOT impressive.
I'll get the lobe profiles in the next week or so. I'm sick of working on the truck right now and just want to drive it for a while.
-Chris
Chris,
Thanks for the info
I was looking into get an H2e after I heard Lawrence hit 787 on the dyno at May Madness with only 38lbs boost. Blair Pine had good luck with his too. Now I don't know what to think.
I saw an old Dr. Performace ad in the TDR saying he has Camshafts. Made from solid billet. 37hp/72 ft lbs increase. About $360.
I wonder how they are?
Keep us posted :)
Congrats on having it back on the road, sorry it did not perform like you had hoped. Sounds like more R&D is in the works.
Hemi, a cam from billet for $360? The grinding alone on a rough cam would be $360 :eek: I honestly do not see how you could make and sell a cam from a rough forged blank for $360, and billet would be triple easily with the volume we are talking about. It would scare me... .....
camshaft
Chris I am sorry to hear your are having so much problem as you are a lot better than I on making a cummins run. Some times a person needs some time away from a project to remain objective. I get very upset when things are not going my way so that is what I do. I wont to thank you for all of the good things that you to the forum. I have not heard of a steel billet camshaft that cheap. LOL Jimk
HEMI,
I think the reason lawrence can do so much with so little boost is because his cam is so good and he has done all the little things to maximize airflow. If you think of boost as restriction to flow then any improvement in airflow after the turbo should lower boost. A good port job should lower boost and a good cam should too.
That's another reason I'm frowning on this cam. I didn't expect to push 46 psi so easily. Not to mention only making 3xx HP.
I believe the turbo Blair used was a hybrid and had a 12 or 14 cm housing, just like what Adam sells. I'm sure that's why it spooled up better than my 17 cm.
I wanted to try this marine cam, but never expected to like it or keep it. I had to try it just so I could form my own opinion from experience and not hearsay. For those of you shopping around, I found a company that will regrind your stock cam for $200. In the same paragraph they recommended Enterprise Engine for other alternatives, so it might be the company that grinds EE's cams.
One advantage of regrinding your own cam is you don't have to worry with the nose of the cam being a different size or using a different keyway so you could reuse your old cam gear ($200+).
-Chris
Chris, could the smoke have anything to do with those modified DVs you said smoke so much or did you change them out?
IMO any improvement in air flow will increase flow to the turbine wheel and increse its rpm causing more boost and more flow to the turbine wheel. The lower the pressure behind the turbine wheel the bigger the pressure difference across the turbine wheel and the more boost you get.
Treven.
Chris,
I did hear of a guy right here on the TDR that lost 65 HP after a marine cam and piston upgrade. It may have been Les Ewin.
Im still looking for his e-mail, phone number to verify.
Sorry its been so tough on ya.
You have a good combo of parts to go over 500HP.
Its gonna take some tweaking and tuning to get it right though.
Wish I could help.
Don~
