This week I got off my butt and finished the Dial a Boost for my turbo. I will be running the turbo at Diesel Thunder, even if it is to my detriment on the dyno... but it will make up for it on the track
(this turbo spools up at any RPM!)
but all my smoke is gone
I installed the turbo on my truck and set the wastgate to open at 33 PSI.
a couple of interesting things happened. With lower boost than the stock turbo: a HX35/14 set for 38 psi, my new turbo ran noticeably cooler at WOT with less boost. I attribute this to the HX40 compressor wheel.
I decided to check drive pressure also.
Boost pressure is sensed at the intake horn, and drive pressure was senced at the exhaust manifold Pyrometer port.
4psi of boost required 4psi of drive pressure
10 psi of boost required 12 psi of drive pressure
and here is what I was worried about
33 psi of boost required 40-45 psi of drive pressure.
there is room for a seccondary turbo. With the wastgate set to open at the OEM HY35 setpoint, I could only make 25 psi of boost,so I am hoping with the addition of the H2E I should be able to bring boost up to 45-50 psi with little rise in drive pressure.
