my turbo seems to WHINE more ok?
27 lbs of boost on a near stocker?
Leaning Truck Survey
my 93 turbo whines some i can hear it spool up just as i shift gears
even w/ open exaust
i dont remimber it before
is it normal to hear it?
any sign of wearing out?
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach in,. Its loud and goes ok, for a 93,Ham radio Call KK6dm
has ability to communicate any where in the world. Headliner shelf
5 antenna's
You should hear it more if you do have Open Exhaust. Isn't it a SWEET SOUND. With Open exhaust, it will spool up faster and louder. This is normal. If you are worried, just take off the air intake and check for any dirt or oil on the vanes. If you see dirt, then change your air filter. Glad too hear another whining Turbo coming to life.
Scott
92 Ram, Bright White, Club Cab, LE package, 4x4, 130K, 3. 54 gears, Auto, Extra transmission Cooler, 285x75x16 Cooper Discovery A/T, 16X10 American Racing rims, RS9000, Tekonsha, Running boards, Lund Sunvisor & bug shield, Marker lights, Tonneau cover, Full cap, DynoMax, 5" Chrome tip, 16 cm Turbo, Isspro Boost, 26 lbs Boost empty, Oil Pressure Gauge, Pump Adj, Sprayed in Bed-liner, Rubber mat
'SHAKES, RATTLES & GOES'
Yeah, the whine is normal so just enjoy. If you still want to check things out for peace of mind you can pull off the compressor side of the turbo without even removing the turbo from the engine. Loosen the stainless steel housing clamp and the two hose clamps that hold the connection from the air filter housing and the connection to the intake manifold or to the intercooler pipe depending on how your truck is set up. Carefully remove the housing so as not to ding the fins on the compressor wheel and look at the inside of the housing where the fins run. The compressor end is where most of the sideplay is and if the turbo is going south you'll see scuff marks in the metal. Note though that if there's any build-up of crud (like I found in mine) you may see some rub marks in that. I just wiped the inside of my housing clean with a wire brush and have had no problems. It may also look like there's an awful lot of side play to the shaft on the compressor end but the Cummins manual calls for a minimum of . 012 to a max. of . 018. If you like what you see on your inspection trip then button it up and happy motoring.
Jones
Jones
'84 Ramcharger w/CTD, non-gated 12, torqflite, NP205, Dana 60 and 70 w/ 3. 07s. Straight piped 3" to x-member 4" the rest of the way.
