Engine/Transmission (1998.5 - 2002) My turbo sometimes lags before kicking in.
Engine/Transmission (1998.5 - 2002) engine codes
Engine/Transmission (1998.5 - 2002) Fuel presser
I have a 2001 2500 HO 6 speed with 123,000 miles. At 60,000 my lift pump was replaced (under warranty!). My problem is that intermittently (5% maybe) the turbo will not kick in at lower rpms (under 2000). If I downshift to raise the rpms the turbo will kick in. Do I suspect another lift pump is needed?
I haven't yet had anybody hook up and read codes and I assume that should be my first step, unless anyone has other suggestions. Thanks
Do you have a boost gage? Under 2000rpm you may not see much boost unless you are accelerating. Cruising down the freeway at 70 I see between 5-8 lbs of boost on level ground at 1800 rpm in OD. At heavy acceleration empty I can achieve between 17-18. Pulling a load I see boost regularly @ all RPMs'.
Hope this helps.
Clay
I am completely stock, with no extra gauges. I am really happy with engine performance overall, as I routinely hit 22 mpg at 70 mph, 23. 5 at 62 mph. I pull a heavy fifth wheel occasionally with no power problems, other than the lagging turbo boost.
Gages!
I would suggest buying gages when you come up with some extra coin. With the gages you'll know what your Cummins is doin! Here's where I got mine... ...
http://www.dieselpowerproducts.com/gauges
I got the white faced Dipricol, Boost, EGT, & Trans temp. Bought the Westach 0-16 FP gage from Geno's. For $330 you get the painted triple A-Pillar, Gages & sending units, The only thing I had to really buy was more wire, & a $100 trans line with the outlet to put the trans sending unit in for best possible spot to check trans tempature.
Good Luck.
Clay
