I think I have setteled on how I want to build my twin turbo system.
For the primary I am proposing a Hybrid HY35 turbo. It will have an HX40 Compressor wheel, an 10cm housing with a 1. 5" diameter wastgate port (twice the size of the stock HX35 or HY35). The wastgate will initially be set to lift off at 25 psi. The 10cm housing will dump into a 4" 90 degree pipe elbow where it will then be routed into a H2E with either a 17cm or a 19cm housing. The elbow will have an external wastgate set to limit boost from the H2E to 10 psi.
With the primary running at a PR of 2. 7, and being fed with 10 psig of boost from the seccondary, I am hoping to get 52 PSI out of the system. This is not designed as a system for wild power numbers, but it should be able to support 450 HP, and spool up to at least 25 psi by 1300 RPM with the ability to swallow enough exhaust gas to keep drive pressure below boost pressure at peak boost.
