I had the same vibration that many others are talking about, after three visits to the dealer, mine is finally fixed. It was a combination of the damper weight on the hose to the hydroboost pump and the front driveshaft. Evidently, Dodge has come up with a new part number for the driveshaft that fixes the problem and, of course, it is on national back order. The dealer left the old shaft out and it is driving perfectly.
Mine is an '04 quad cab 3500 dually 4x4. All '04's were supposed to have the damper weight already on from the factory but mine did not have one. Make sure yours does, it is easy to spot. Look on the top hose from the PS pump to the hydroboost pump and there should be a fairly large C shaped lead weight attatched to the hose.
Try this, hope it works for you.
