I decided I wanted a switch to control Lockup, Unlock, and Auto (PCM controled) Well you want to start out and find your Orange with black stripe wire that controls the torque converter. I cut the wire in half and then soldered the two longer lead wires from both ends and ran the wires to under the dash. One green and one white. Green goes to Torque converter wire (goes across the engine fire wall) and white to PCM(3 modules on the passenger side fender). Then I ran a ground wire to feed the manual lock up. I got to brain storming and decided that I want to have something to get my attention if I forget my switch in manual lockup mode. I added a buzzer that I had laying around. I took 12-volt power from the brake switch so when your slowing down and you put your foot on the brake and the switch is in manual lockup mode the buzzer will BUZZ to alarm you. To find 12 volt, check all wires and find one that has 12 volt when brake is pressed. I used a white wire with red tape for positive side of buzzer for this one. Ground will be added in at the switch. Next was a location for the switch, this was a hard one. I decided it would go on the left side of the dash just under odometer on the plastic shroud. Now comes the wiring, I bought a 6 pole 3-way switch from radio shack for about $6. The solid white wire went to #4, Green went to #5, and Black went to #6. Now we need to add a jumper wire for the buzzer (jumper wire is a ground). So a jumper wire on #6 to #3 and white wire with red tape to #2. You also need to take out the transmission relay out add a jumper wire. So now you have Manual lock up then manual unlock then Auto.
