Engine/Transmission (1994 - 1998) mystery switch help...
Engine/Transmission (1998.5 - 2002) Trans upgrade 101 - steps
Engine/Transmission (1998.5 - 2002) lift pump lube
Hey gus I need a little help. I found the mystery switch instructions on the TST website and have a few questions.
My 1995 was built in jan 95 and it doesn't appear to have a trans relay. the Power dist. Center fuse box lid has a legend and it doesn't have a trans relay listed. it has an Auto-shutdown relay in place of where the trans relay is pictured in the instructions. any help??
Also, the fuse blocks and relay for my ABS is not installed, yet I know for a fact that it has ABS... . I've used it a few times! :eek:
Anybody had similar problems?
You looked at the instructions for the 47RE transmission. You have a 47RH. No relay involved. '96 and later trucks have the relay for their 47RE transmissions. If you don't have a messy contraption on the fender well just in front of the firewall on the driver's side you don't have four wheel ABS. Only RWAL which is for the rear wheels.
my goof...
Thanks guys, I re-read the directions after I posted that and realized my mistake. Ever had that problem where it is hard to talk because of how far you stick your foot in ??? Or possible the muffled sounds when you head is so far up your @$% that you can think?? :-laf
