hey guys, haven't been on in awhile, I'm assuming your all doing this as a way to help stop the truck. Just my 2 cents, my wife drives a power stroked van with a/t. So I put one of those electric exhaust brakes in it, the one that work off the warm up valve. It opens and closes to help warm up faster, some genius figured out way to use as exhaust brake. I put in in less than an hour, the only mistake I made was buying the torgue lock switch for the extra $20. Believe me the exhaust brake is enough, there is way to many possibilities of severe damage with using the lock up switch. I used mine 2 or 3 times and disconnected it. I saw in a few threads guys asking about coming to dead stop with it on, and the answer being like manual with out steeping on clutch(somewhat of the same feeling) but more severe to trans. If you do decide to go with setup, DO NOT start up truck with switch on and make sure you turn it off between 20 and 30mph, and shouldn't even turn it on until 55mph. I think to much work and way to dangerous if have other people getting in and out of your truck. If someone plays with switch or someone forgets to make sure off before starting could cause major problems. Best of luck in your decision.
