Engine/Transmission (1998.5 - 2002) Mystery Switch????
What is the best way to add a Mystery Switch on a 2001. 5 truck? I have seen i few instrustions but not for my year... Can you please send me in the right direction.
Thanks
kevin
I have a switch diagram in my gallery you may want to look at. I'm using two LEDS, a yellow whenever lockup occurs and a red when it's forced via the switch. When the switch is engaged both are lit, makes for a good reminder to turn it off when your coming to a stop. I got it from another TDR member and it works like a charm.
I think TST has some instructions on wiring that you should look at too. You need a jumper wire in place off the trans relay... black box beside the drivers side battery.
