Can some one confirm the jumper wire placement for a 98 12V. I removed the relay as stated in TST's instructions and then ran the jumper wire between the two larger connectors. When I turn the key on I get a high pitched noise coming from the passenger side of the engine compartment. Possibly the ECM. What will happen if you ground the circuit and leave the relay in with out the jumper wire? What is the exact purpose of the jumper wire?
Thanks
Thanks
