Mystery wire
It lives
Rotellat4 vs T5
Can’t quite figure out where this one goes
+1 on the Oil Pressure Sending unit.
In you picture there is also a Ground wire (sitting loose on top of the motor mount in your picture) this bolts to the block by the starter, I think it one of a few ECM grounds.
All ground connections are mandatory on these trucks.
that was the next mystery wire I was wondering about thanks .
I believe the only other 3-pin on that side is the MAP sensor. What year is this truck and what color are those wires?
It’s a 99 and i think it’s got to be the crankshaft position sensor thinking about it because it and the map sensor are w only two left it just hit me . Now hook that ground up. I’ll let you know for sure Monday when I get back to the shop
Ok so we did have some serious routing issues think I’ve got everything right now . Now I need a new map sensor because the shop broke it
