Nalco/Exxon TD-4 plus fuel additive? How does it work?
Have you used Nalco/Exxon TD-4 plus? How were your results?
Did it quiet your injection pump? Increase your mileage? Prevent gelling?
Where might this fall on the LE DCI+, Stanadyne, Howes, Power Service continuum?
If it's any good I have access to 48 bottles (4 cases) for $3. 14 per bottle. I don't know what it would cost to ship... But if you want some it might be a good deal.
The label claims it treats 480 gallons per quart. Must be strong stuff.
I've searched the web and only found the following back from 1998 or so... . Maybe it's out of production?
[from a trade show's web archives]... . "Two important additives for diesel engines will be set forth by Nalco/Exxon Energy Chemicals L. P. First on the list is TD-4 Plus, a diesel additive that is said to offer year-round protection and performance for RV engines by providing improved mileage, reduced deposits, quick cold-starts, protection against fuel degradation, and protection for engine parts against corrosion. The second product, TD-4, is an additive designed to protect diesel engines in winter. It is said to prevent fuel from jelling down to 35 degrees below zero, improve cold-weather starting, prevent fuel-line freezing, and reduce fuel filter icing. "
My purpose in the post is really to find out about this product for myself, not to sell it. So I would really appreciate the benefit of your experience with it. Or even rumor... .
thanks,
Chris
thanks,
Chris
