Name plate removal question
ford joke
Time to tap the TDR unlimited knowledge base again.
I've removed decals on all my vehicles, snowmobiles, atvs and dirtbikes. The easiest I've found is to use either a heat gun or a hair dryer to warm the adhesive. For hardened emblems, heat them up and use a piece of fishing line like a saw behind the emblem. For decals, heat them up and peel them off. There will most likely be adhesive left on the truck. I use 3M adhesive remover in an aerosol can. Spray the remover on the adhesive and wipe off. You may have to repeat this step a couple times. You can get the 3M from a glass or windshield shop. Goo-gone will also work.
