I had to haul a truck to Denver today from well south of Grand Junction. I scaled at 15,600 no big deal. Not until I realized the exhuast brake had quit working
OK, still gotta go, no big deal. I get 300+ miles into the trip, I am pulling a steep grade just a few miles out of Denver, 30 psi, 1300 EGT, hard but not THAT bad, all the sudden no power, exhaust get louder?, boost down EGTs going up. Pull over, idles OK, not much power though. Its mostly downhill, I go for it.
Get it to the dealer in Golden, yep he has the most and the best techs in town... . maybe Friday, for sure by Monday. I try to explain that I made a day trip from 350 miles away and I can't hang out, nor do I want to, in Denver. No help. So a little frustrated, I honk on her pretty good out of that paking lot. Damned if it doesn't clear right up. I drive it around the city a little after dealing with the truck delivery and rental trailer. No problems, makes it home 350 more miles, no problem.
It set the following codes
P0204- #4 injector
P0234- overboost
P2149- injector harness #4-6
It was running pretty rough, pretty loud, high egts, could all that drama be from one injector? Is it the Quadzilla box? Didn't seem to matter the setting, and it was on the lowest one when the problem occurred. Checked oil, good level, no fuel smell.
So check wiring for #4 obviously. I need the e-brake fixed and was going to hit the dealer up for a new DM flywheel since I have some extended coverage left.
What do you guys think?
P0204- #4 injector
P0234- overboost
