Well, the last time the truck ran was at the TS race a couple months back. . I believe water pressure was my problem causing a blown headgasket. That was taken care of with an electric pump. I also went ahead and installed a billet cam. The truck had good power in Bowling Green, and rolled through the eighth mile traps at 94 mph with only a few seconds of wide open throttle. I put it on the dyno, and this thing is making no power or torque. I could only make a third gear pull with no lockup, but the numbers were horrible. It was around 500 hp, and 700 torque. Everything seemed to be screwed up. . My boost gauges were hardly moving. I don't see how I could have trouble with boost gauges, but I did, even though everything looked fine. I did go with . 120 lines instead of stock, but I didn't think that should hurt much. timing was set at 23 degrees. I spun it to 4500 rpm in third. . Wheel speed was 121 MPH. I just feel something must be bad wrong to show such low numbers. . Especially the torque. . Does anyone have any ideas? I'd love to go to Rockingham, but there's no way I'm taking it the way it is. Anyone have an idea why the numbers are so low? I don't even know how to set my wastegates, so that lets you know how lost I am. I may have to make a call, and see if Garmon can get me in. .
I came to KY to get the race truck and go to Rockingham, and already broke the output shaft on my daily driver dually as well. Not a good time so far.
