Engine/Transmission (1994 - 1998) Need ~800lb tourque....what bombs?
2nd Gen Non-Engine/Transmission Exhaust Drone
Engine/Transmission (1998.5 - 2002) Another APPS
Going to help a friend who's purchased a '96 12v 5spd. It's as factory as factory gets. . only thing done is straight piped.
The truck is used as an everyday driver but also is required to tow loads of ~17000 lbs.
As mentioned it's a '96 5spd 12v. He figures 800ft/lbs tourque should do it. What's it going to take? I'm thinking it would need a fuel plate, he's got a K/N filter and injectors and maybe a piers 3k gov kit too. With these bombs can he reach that much tourque? I'm also thinking that a set of guages would be in order as well.
I need to know details like specifically what fuel plate and injectors would he need. Also if you could ball park the horsepower from the required combination.
Thanks for any help. .
Gauges first. Then maybe a #12 or #11 plate. The #10 might be too hot for towing if he's still running the factory size exhaust.
I would venture to say he'll need a bigger turbo and exhaust to get in the 800 torque range and still be able to tow 17000#. HX-40, 4" exhaust. Then he should be able to run the 10 plate and possibly 370 injectors and a GSK. That should put him in the 800 torque range, no problem.
With my 97, I was able to run 405 on the dyno with just the #10 plate, 370 injectors, and a GSK. NO exhaust upgrades, but this truck only three times in 3 years.
#10 and 16 cm2 exhaust housing. Pyrometer mandatory. For heavy towing, may need 4" and HX40. I dyno'ed my prototype #10 at 860 ft lb.
See my sig below for my mods... . my truck made 351hp and 885 ft/lbs to the ground. I have towed a 16,000# front end loader with NO effort at all..... make sure your friend has a good exhaust brake as well
Best of luck
Thanks for the infor guys.
I'm not sure if he's set on getting a new turbo or housing. . maybe he'll have to settle for a little less.
FreeBMW,
I looked at your sig and did not see any injectors listed there. Are you making that power on stock manual injectors?
So far the list would look like this
-Piers 3k
-Not sure about fuel plate due to heat for towing
-guages pyro,transmission,boost
-injectors maybe doesn't need them?
See my sig, that is about 850 tq. There is no way he can tow that much with that kind of torque without spending a chunk of money on a hi performance clutch. Without gauges he will get to rebuild the engine soon also.
