I just got my 6-speed in last night and it's got problems.
It was one I got that was lightly used as a Dodge test trany. It looked like it had very few miles on it and not much rust on the case. It's an '02 version as far as I can tell. Anyway compared to the other two I got, the input shaft seemed quite loose and would even hit on the housing around it. The other two would not do this. So I went ahead and added some shims to tighten up the main shaft a bit. Well now when I drove it for the first time it seems to be binding (shudders) in all gears except direct (5th). The more load I put on it the worse it is. It is the worst in 2nd and 3rd I think. Is there anyone here who can tell me if this might be caused by the main shaft being too tight or might I have another problem? I also added . 003 to the counter shaft, which left it with a tiny amount of end play. I am guessing on all this because I don't have all the attachments to hook up a dial indicator and plus I would have to pull the rear housing off to check it. The specs call for . 002-. 006 end play on both shafts. I'm FREAKING out here and hope I have not killed something already in my 20 miles of testing. I wish I had the money to just have an expert set it up and make sure all is well. Oh it shifts great!! This is what I was worried about and now that is fine and I have something else going on. There has to be a trany expert on here so if you see this please speak up!!
Edit: As I think back on this thing before I did anything to it, it was harder to turn then the other two. If I held the output shaft when in neutral it was even stiffer, which is normal to some extent but seemed almost excesive. I figured that since it was so new that maybe it was just not as broke in as the others and that may still be the case. Help!
Thanks,
Mark :{
Thanks,
Mark :{
