1978 Ramcharger conversion to CTD.
Here it is guys. This started out fun but has taken a bit of a turn. I'm converting a 1978 Dodge Ramcharger to a CTD. I have everything that I need except a bit of knowledge.
I want use the 1991 frame and shorten it... by 25 inches... The section to be removed leaves me with very little "bolt and place" space for a long plate, but the frames will be VERY close ('78 vs '91), if I can pull it off. The catch is... I don't trust the '78 frame... Hard P-Side hit at some point. The '91 is very straight and clean.
Can anyone give me some opinions about this "cut and stitch" that I need to to do (or have done). It is a critical weld and I want it right. Pros-Cons??
Any insight???
Thanks!
Andrew
Any insight???
Thanks!
Andrew
