I've been looking for a 93 W-350 dually CTD club cab for some time now. I have my eye on one that needs some body work, xfer case & 518. I've been into gasser cars/trucks for a long time so none of that stuff scares me but I'm a newbie to the CTD world. The NP205 won't go into any gears so i can't drive the truck at all. Engine starts easy and has good oil pressure for about 15 seconds then falls off to almost zero psi at idle. Pumps up to about the middle of the operating range when you rev the motor but falls back to near zero just as fast. It huffs a bit of blue smoke from the tail pipe but not terribly bad. Truck is supposed to have only 119k on it. It is very clean underneath, chassis, suspension and under the hood. Does not look like it has ever had the typical used car lot (which is where i found it) engine degreasing which strips all of the plating off of the various lines, hoses brackets in the engine compartment. Both doors open nice & tight and don't have the normal hi-miler slop.
So I'm thinking that this is indeed a 119k mile truck but what's up with the low oil pressure & the blue smoke? Is thisa common problem at 119k or is this a sign of a bigger problem. How bad would you have to treat a rig like this to wear out the 5. 9 and grenade the xfer case at 119K ?
I really like this truck, color combo, options, etc. and can't find anything better on this side of the continent. I can buy it for around $3500 plus I'de end up spending nearly addl $2k to fix the 518 & np205. All-in-all after body work, new paint, and all of the little things I'm sure I would have 10-12K in the truck. I'm fine with that but If the motor is no good then it's a bad deal.
What would you do?
What would you do?
