I ordered a gauge set from Vulcan with pyro, boost, and trans temp. I Have a question about the hookups for the boost. It came with three fitting. The one obviously hooks into the gauge. Then there's a coupling of sorts that the other male fitting goes into. My question is, where do I tap into the air supply. I thought boost botls replaced a bolt in the intake, but the male fitting is a touch too big and the threads are finer thread. I can't find any other size bolts on the intake plate, so, what am I not seeing?
Also, the gauge A-Pillar doesn't seem to fit around the other very good. Is this normal? I'll try heating it up a little and bending around the reg. A-pillar.
Thanks
TW
Thanks
TW
