Engine/Transmission (1998.5 - 2002) Need a new clutch.
2nd Gen Non-Engine/Transmission What tires to go with ?
2nd Gen Non-Engine/Transmission Cruise control
I have to replace my clutch, however I do not the cash in the budget for the Con O from Southbend, anyone have any other suggestions for another clutch that is a little less $? :{
Thanks
Fred
I've got the centerforce dual friction (13" for the 5600) and I am very happy with it.
I slipped the stock clutch with just an EZ. I can't slip the centerforce clutch while towing a 10K trailer. The pedal force is marginally greater, and it took about 1 week to seat in good (grabby until then).
If I had to do it again, I would use the same disk/pressure plate combo.
Make sure you turn the flywheel and replace the pilot and throwout bearings.
South Bend has a clutch called the "rally" that is rated for 350hp. I had one in mine till recently and it held my dd3's and comp fine when the truck was empty and I just turned the box off when I towed. It was right around 3 and a half. Might be able to find it a little cheaper or maybe a little more, that was two years ago that I bought mine
Augustus said:
I found some on the internet, are they available at the auto parts store?
Don't know. I got my kit on the internet from Jegs.com for under $600 delivered to the door. For another $60 you can get next day delivery.
(On Edit) I see you have a 5 speed. Jegs has 183-DF989984 Centerforce for under $450 delivered. Think this is your kit number - pls check. Does not include the pilot or throwout bearings.
The Centerforce pressure plate is a LUK core with the weights added to the release fingers. Don't know about the clutch disk compositon differences between CF and LUK and how CF sources the disk.
I considered the pro gold, but could not find anywhere where TDR members had experience with it. Also LUK did not state any ratings on the kit.
Centerforce claims 90% over stock holding power for the Dual Friction, which is what I went with. I know the 90% is a weak foundation and don't know how much testing they did, but my experience with it has proven good.
the LUK Pro-Gold (13") is about $525... the center force is around $600... I can't find anyone that has had any experience with the LUK one, outside of people that stayed stock and never really towed... most that I have talked to with the center force love it... so for the extra $100 or so I'll be getting the center force... . soon... :-laf
I just did this last weekend.
Remember the saying about the sweetness of low prices being forgotton due to the sting of poor service?
Buy South Bend, they are first class people. You may pay a tiny bit more but when you factor in the amount of labor involed to get to the clutch, it's worth it. This is my second South Bend clutch (different truck), and I am saving my pennies to get one for my wifes 12V.
I have pictures of the replacement if you like.
To save your money and time in the long run buy a south bend. A lot of the clutches that i sell are to guys that have a LUK or centerforce. South Bend's service is great good people to work with.
