Need a rear hub bearing carrier for 93 W-250
trying to build a dually
Superduty transmission fluid cooler
Madurski
I need a rear hub bearing carrier for 93 W-250. The splines in the flange are stripped out on several of the lug holes on the one I have. It is not available at the parts stores. I have tried uneedapart . com but have no replies yet :-(
Let me know if you have one and how much you want for it.
Thanks,
Ron
Atlanta Gear & Axle, Inc.
I've found that Atlanta Gear and Axle can get pretty much whatever Dana/Spicer part you need at a reasonable price. Call them with with as much info as you can off of your axle.
Are you talking about where the wheel stud goes through the hub?
A few backwoods fixes to get you back on the road would be to clean the hub and use bearing mount compound to hold the stud in place or to tack weld it to the hub to keep it from spinning when you torque it or break it loose.
