Need advice ASAP...
Leaking 48re
Injector question
Well, started the truck up today to run errands, idled fine, then all of the sudden, it started knocking, bucking and smoking like crazy... shut it down immediately.
I assume injectors?
If so, I might as well upgrade, any advice?
Truck has an airbox, 4" exhaust, Airdog fuel setup, and I run a Smarty.
Don't plan on upgrading the turbo... until I HAVE to ;) ...
... and I tow a heavy fifth-wheel pretty often, I travel for a living.
And, if anyone has any advice on good shops in the Dayton OH area, it would also be much appreciated.
Thanks!
Update... had it towed to a local shop, they did the test where they turned off the injectors one at a time... when they shut off #6, it idled fine.
Then they unplugged the diagnostics, and tried it again and everything was fine.
He thinks the plunger got stuck and when he turned off the injector, the pressure-release "unstuck" it.
No codes, no blow-by, no fuel in the crankcase, I'm very happy right now.
Especially since DonM is on a two to four week wait for the nozzles for the F-1's and that's the next upgrade I want, just couldn't justify it until the stock ones started acting up lol.
If it stuck once, expect it too happen again.
go get a big bottle of the power service diesel kleen and run it. also as a cummins engineer said run the **** out of it. I have knowticed that if mine is babyed to much it starts to run rough but when i run it hard and make it work its much happier.
I'm not sure how it can run fine wiht the #6 injector off.
I rented a DRB III and turned off one injector at a time just for the hell off it and with one injector not firing it idled very rough.
FYI, If you decide to do a turbo and want to save some bucks a cheap way to go is to use a 04. 5 or newer turbo. They flow a lot better than your OEM one does.
Ryan, I went to Warren County diesel, good shop?
pm if you would with any advice.
Also, I need to proofread my own posts, I didn't mean it idled "fine", it just quit belching the smoke and knocking, sorry about that.
Thanks for the heads up MMeir, I know problems usually don't just go away, so I'm prepared for it to happen again, and it's got me off my butt and researching the different injector choices, so far I think f1's are in the lead.
MA2LA, thanks for that info, I'll do that ASAP, or run a couple of canisters of SeaFoam straight into the Airdog, I think I have the SeaFoam on hand.
... and thanks for the turbo info WoodChuck, that's one I didn't know.
Definitely try this... run it hard, and loaded heavy if you can...
I have no idea. I'm just curious what people use around here.
Ryan
First time I've used them, seemed like a bunch of good guys... all gearheads, all have bombed trucks, sledpullers etc.
Main shop guy has a badass '69 Camaro dragcar that he personally built most of.
They only charged me 75 bucks for the diagnostic fee, no hourly also.
