StevenWalker
Recently, I had been driving my truck down the interstate for about two hours, the truck suddenly lost power then just as suddenly regained power. It did this off/on/off/on situation for about 15 seconds the first time. It was as if some turned the ignition off then on rapidly. Then a few miles later it did it again. The episode lasted a little longer. After reaching my destination, the truck sat and cooled off, the problem seemed to go away. On the return trip, the off/on/off/on problem occured again after about an hour.
During these episodes my fuel pressure drops momentarly from about 13 psi down to about 5 or 6 psi. When the engine catches again, the pressure goes right beack up.
It I disconnect my Edge EZ and ran it as stock. The problem still occured, but much less frequently and the duration was much shorter. I scaned the truck for codes and there were none.
So, has anyone got any ideals on what might be going on or where I should look next?
Thanks for your input.
