While going around the Beltway at 75 MPH this weekend, my truck felt like it had shut off. I looked at my guages and saw boost drop to 2-3 pounds. I pushed harder on the throttle, and it took of again after the boost spooled up. After searching the forum, I decided it could be the MAP sensor connector was dirty. Before I cleaned that I checked the codes and found 1693, 1694, and good old 0216. The truck is an 02 with only 34500 miles! Should I take out the superchips program before I go to the dealer, and will that clear that 0216 code?
2002 2500 6 speed Superchips BHAF Guages ARE cap
