Originally posted by Idaho CTD
Dang Cliff,
You have more control than most Bombaholics. Actually thinking of a pulse instead of a comp, never would have thunk it. 358hp isn't what it use to be huh?
Nathan
358 is still fun!
Actually I stopped by a (sic) shop yesterday to borrow a few electrons in an attempt to make my Power Puck obsolete prior to Diesel Thunder... . it did not work like I had hoped to... so the Puck is plugged back in.
the reason I am thinking of the Pulse vice the COMP..... I have a stinking suspicion that with a COMP on 5x5 wil be very close to a Pulse with the jumpers on 4x4 when installed on an ETH..... however I may be wrong, but here is my reasoning behind this... . and it is full of quite a few holes
I have seen an ETH with a COMP on 5x5 dyno at 383 with DD2's... on a Mustang dyno
I know of an ETC with a COMP on 5x5 dyno at 412 with the same basic bombs as the perviously mentioned ETH... . on a Dynojet Dyno
however this is on two different dyno's. The dyno run with 412 HP, I ran at 300 HP (Dynojet dyno) with just 275's and the Puck... . I also ran at 302 HP with the same BOMBs on the local dyno here in Hillsboro which is a Mustang.
I set up the Mustang Dyno here in Hillsboro as close as I can to the Mustang Dyno where the 383HP ETH ran for my 358 HP run... so I am assuming that since I was within 2 HP on two separate dynos, and I set up one Mustang dyno as close as I could with respect to another Mustang dyno the 412 HP ETC and the 383 HP ETH runs are accurate.
Have I lost you yet... now I am even starting to get a little confused.
I think that with the COMP I could only get at most 400 HP from my truck, where with the Pulse, I would be at about 380-390. Now if I had an ETC, I would be at almost 450 HP with a COMP and my DD3's. I think you reach the point of dimishing returns faster with an ETH, so I am wondering if a COMP is worth it over a Pulse when slapped on an ETH
