Problem - truck won't start.
History - Owned my 99 24V since November and has run like a champ. Fueled today at a station I have never gotten fuel at. Added 1/2 bottle of powerservice as usual and drove 40 miles to work with no problems. At the end of my shift, I opened the fuel filter water drain for about a five count and then cycled the lift pump twice to make sure the housing is refilled. I do this weekly or at least once per tank of fuel. I then started the engine and it ran fine for about 10 seconds and then started to idle roughly and miss. I tapped the pedal and it stalled. I cycled the lift pump several more times and attemped to restart. After several tries it caught but quit again immediately with a huge cloud of exhaust.
So far I have checked that there was fuel in the filter housing (opened drain for a second to see if any came out - it did), cycled lift pump several more times and cracked the inlet banjo on the hi-press pump to make sure there was fuel there (there was). I have not cracked the injector lines yet as I was freezing my butt off and couldn't see too much...
Anyone have any ideas what I should check next? Bad fuel? Bad filter? Air in fuel lines?
Any advice would be appreciated.
Thanks - Brian
Thanks - Brian
