Archived need alignement info badly
Archived No start problem
Archived Locked Out!
I am trying to cure the death wobble again,,replaced track bar. .
i will put new Michelins on when i get the proper alignment.
A local garage put in lots of caster like it was recommended on this site..... BUT they did something i seem to remember being warned against,,,,the clock looking things for csater adjustment are not pointing in the same direction,,,is this bad,,,,
What is the best way to align these truck... .
Thanks
In a previous posting written by ???? (don't remember), they were complaining about a shimmy in their
Ram 4x4 after striking bumps in the road.
I suggested that the front end alignment has either too little or too much caster, thus causing a caster
shimmy. He did not like my response and changed his concern from a "shimmy" to a "bounce" (big
difference), and insisted it was the shocks. Maybe it is, I haven't driven it. He also said the alignment
"checked out". Here's the problem:
Alignment programs (and service manuals I believe), give a wide acceptable range for front caster on
the 4x4 Rams. I believe the range is 2 degrees to 5 degrees (if that's not correct, it's pretty close). The
problem occurs when the alignment tech (independent or dealer) tells you that the measurements
"checked out fine", just because they were in this broad range of acceptance.
Caster readings that fall on either end of the scale are subject to caster shimmy, even though they are
"acceptable". I had to align some 30 trucks and attend a 9 hour "Dodge Ram Chassis Dynamics
Diagnostics" training session (fancy name, ehh?), before finding out that 3 degrees to 4 degrees is the
optimal caster setting for 4x4 Rams that eliminates caster shimmy.
Below I will post what specifications I set Ram trucks to. First I want to give a little more info on correct
Ram alignments so you can see if you had a job well done,
The eccentrics on the lower control arms ARE NOT for individual wheel caster adjustments (even though
our alignment machine says they are). The eccentric sleeves in the upper ball joints are for adjusting
individual camber and total cross caster (difference in caster between two front wheels). This is why
replacement eccentrics are positionable in eight different ways.
Once camber and cross caster are attained with the eccentrics, the lower control arm eccentrics are
then used to swing the caster readings into specifications. The two eccentrics must be swung in the
SAME direction in EQUAL amounts. If they are not, it will create a setback condition (one front wheel
further forward than the other).
FYI - Comparing between the two front wheels, caster will cause a pull to the smaller value and camber
will cause a pull to the larger value. A truck set up with caster pulling in one direction and camber
pulling in the other direction, can lead to a wandering truck; even though it is "in specifications"!!!!!!
If the eccentrics on the lower control arms of your truck are not pointing the same direction, the
alignment was done incorrectly and the axle was "twisted" or "forced" into position to attain the
acceptable values (seen them from the factory this way, go figure).
A correct alignment will set the truck up with a slight negative cross caster (truck has slight pull to left)
to compensate for right hand road crown. Camber will be equal side to side slightly on the negative
side. This will help maintain acceptable camber when hauling heavy loads, as the truck tends to lift in
the front when towing. Camber will then fall slightly positive when towing.
Just because the alignment shop says "it's in specifications", that does not mean it is set up for proper
performance and handling!!!!!!!!!
Specifications (my personal settings for every Ram I align): all specs below are in degrees.
Left Wheel Right Wheel
Caster 3. 2 3. 5
Cross Caster -. 3
Camber -. 10 -. 10
Cross Camber 0. 0
Toe - standard specs, (maybe a little out if you tow a lot, they will pull in as the front end lifts up).
Brent
ASE Certified
Gold Certified Chrysler tech
WyoJim
What settings would you recommend for a 92 Dually? I was a flunky in a front-end shop along time ago "80" and we set the front end as you suggested to compensate for the crown of the road. The only problem is I don't remember what settings we used for the Dodge trucks. I'm experiencing the death wobbly and it is getting worse, once I rebuild the front-end I want to get it aligned properly.
TIA
Alan... That post is a copy of a post made a long time ago by a guy named Brent. He is a certified tech.
I think the first generation trucks are a whole different beast and I think they have a better front end than the second generation.
I bet factory specs will work on them.
