We haven't towed anything for a quite a while. We're getting our wood floors finished and even though it's a water base finish, the odor is pretty unpleasant. We're going to rent a travel trailer for the two days that the finishers be applying the finish.
I needed to replace the trailer plug on the back of the truck. When I was checking all of the connections with a multimeter, the trailer brake wire was reading a constant 11.5 volts with out brakes or using the manual slide. The reading didn't change much when I did activate the slide. I've had the Draw-Tite Activater ll for ever, so I figured it was shot and bought a Activator lll. Same results. The blue brake wire reads about 11.5 volts. I checked voltage going into the controler and it's about 12.2 volts. Any idea on what's going on here? Any help would be greatly appreciated.
