Need Auxillary Trio Gauge Set for 92 dodge
235 85 r16 rims size
Dana 70 carrier R&R question
USDieselParts.Com
genos is pretty good, but this site is the best ive found. i got the boost and egt set, comes with the dual a-pillar mount and all the necissary parts for both gauges.
for the tach, same site. here are the specs and prices:
Here are some of my posts from the Sticky on this topic.
The 4k rpm tach P/N : R8503
Wiring kit for pre-94 Dodge Cummins P/N : R8912-92
hope this helps (if i recal i got both for a good deal. USDieselParts. Com is fabulous, their where i got the tach and wiring kit and my other gauges... easy site to use and great prices. customer service is great too. )
i think in total it set me back right near $160 for the tach and harness. if you get the set up make SURE you get the R8912-92!!!! the "92" on the end is crutial. they offer a R8912 that is for pre-92 trucks. the R8912-92 is for 1992 and UP models.
4k Tach : $115. 41
Sensor Harness : $38. 54
i run all isspro. i got the 40 psi manifold boost gauge. i like that cause the 60psi, i think is overkill, cause i probly wont get over 40psi. and with the lower max, i can acutally see the gauge move. ive hit 21psi so far, and its nice to see the needle just over center.
egt, i got the rainbow one, 1500*, pre-turbo.
