Need carrier bearing info
4wd engaging by itself?
Nasty shudder decelerating 15-10 mph
How much work is involved in replacing the carrier bearing on an 06? Also, does anyone have any sources for them other than the dealer, or part numbers? All I have is the OEM number (5183075AC) which is expensive. I've been online for hours searching for an alternate with very little luck. And is there different numbers for FWD and RWD? I found one at Advance that says RWD, but have not seen any reference to FWD/RWD anywhere else. Thanks.
Or you could just replace the whole thing with a 1 piece drive shaft from Dodge, ready to be bolted in (assuming 4WD - I'm not clear what you have).
Just a thought (and what I did)
Scott
Can you send me a link to the carrier bearing? Rock auto was the first place I checked and I couldn't find it.
