2nd Gen Non-Engine/Transmission Need correct part description
I have rubbed a hole in one of my A/C lines. I need to know the correct name of the line running from the compressor up to the top of the condenser out front. I think this is the discharge line?? Thanks in advance for the info!
That would be a high pressure supply line from the compressor to the condenser in the grill. The gas condenses to a liquid in the condenser and is sprayed by an orifice in the evaporator in the cab. It then returns to the suction side of the pump as low pressure, large hose.
mebe too much info, i duno heh. .
ebay has a set of hoses here:
http://cgi.ebay.com/ebaymotors/ws/e...tem=7974239900&category=33544&sspagename=WDVW
duno if the gasser 1500 hoses are the same but for 9. 50, i`d find out at the dealer... good luck
-j
My line got a hole also. I repaired it with that Alumaloy rod that you see on TV all the time. I put wet rags on both sides of the hole first to contain the heat, then went at it. After it cooled, I just charged 'er up and its been fine for the last couple of years now.
