Need Cubbyhole and Driver's A-Pillar
Vacuum pump seal
p-7100 timing
Any of you guys that made a custom center console, have the cubbyhole for manual trucks laying around collecting dust? I need one and www.mopar4less.com won't return my phone calls. I need it in agate, PLEASE?!?
I also want to take my gauges off of my A-pillar so I need a new driver side A-pillar in agate also. Any reasonable offer will be considered.
SURE!
Mine is the one with a tweeter, and I had to enlarge the tweeter hole so that a JL audio tweeter could fit in it.
blkdawg
I have the black plastic cubby hole insert for the dash as a stock item. I didn't know that hey were in agate also...
I make a panel for the cubby hole and it is a textured surface plastic peice that you can cut out a hole for gauges or whatever. .
Would this help?
Eric
Originally posted by Idaho CTD
Janderson,
Most A pillar guage mounts go over your existing pillar. IE you need your stock one to mount the guages to.
Nathan
... ... ... . true, but you can use the A-pillar cover as a substitute for the OEM. i cut the top portion of the OEM off (down ro below the clip), then glued it onto the back of the "cover" and used that setup to hold the new mount in place.
