Need DC part # for TPS..
finally some respect from my ford drivers
How much ATF after DTT VB/TC change?
Can someone give me the Dodge part number for the TPS. It's on a 97 4x4. I'm trying to
see if my local jobber can get some at a reduced rate but he needs the DC number.
Thanks
97 2500, extcab, 4x4. BFG 285/85/16 AT, "warmed over" pump, JRE Stage III plate, AFC spring kit, BD gov. spring seats only, 370 injectors, K&N, 4" Edwards Exhaust with Dynomax straight through racing muffler & 5"tip, (Cat got "lost"), EGT, boost, oil & transmission temp. gages, Low Stall torque conv. & BD valve body, silencer ring "exiled", Grover Emergency air horn and a multitude of strobe lights and switches (Vol. firefighter)
Rammin On
Thanks. You be da man ... ... ... ... ... .
I just ordered one last friday and it was here monday. I used PN 3930318, I think they changed the #. If you look in past posts about the TPS there is more info. As far as I know this is the updated number because i got the right part.
95 3/4 ton, 4x4, Auto, 235 plate, K&N, straight through exhaust, wastgate mods, more to come, 108,000mi and still going strong
