I'm going to be hauling a load of live shrimp about 800 miles, from Texas to Alabama. The Owner's Manual lists the GVWR at 6400lbs. The shrimp will be in two "totes"--containers molded to a pallet-type base, that contain water to keep them alive. We are estimating that the weight of the two totes, filled with water and shrimp plus an oxygen tank will be right at 5,000lbs. I'm about 160lbs and the gear I pack will be less than 100lbs. So we're talking a maximum of 5500lbs. total weight, plus the truck itself. The totes measure 4'x4' each, so they will pretty much fill the bed. How do I calculate the GAWR (3300lbs front, 3600lbs rear) for both the front and rear axles, and am I within the ratings of the truck, considering it's a 2500?
Thanks.
Thanks.
