Details here: TDR Privileges
I need some help, need the tightening sequence for the head bolts and the torque specs for the head and exhaust, if the exhaust has a certain order it needs to be tightened, that would be helpful also. Thanks in advance
If you don't want to get the service manual from Dodge or Cummins, the Haynes manuals have the diagram in them. I don't have a scanner, so I can't help you that way.
a helpful tip: "GENERALLY" not always but about 90% of the time you can use this method. Start in the center and work 'spiraling' outward. As for the actual torque I can't remember off the top of my head.
