Need heater/defrost unit
Dead at 175389
loss of power.....
Yep, mine's broken where the cables attach so I can't control temp, heat/defrost.
I've epoxied it and it's curing, but I wouldn't bank on it holding for long.
So... . anybody know if this thing is available? I don't have A/C, so I need heat/defrost only.
I'll start searching in a few minutes, and will make a call to some _ealers tomorrow.
TIA.
Jay
EDIT a few minutes later.....
I found one at dodgeparts.com for $25 so it's on order
HTML:
Replace the cable also. Most likely it is bad to
Actually they feel fine... . the pyrometer wire and boost tube was laying in that general area... I'm thinking it may have gotten caught and snapped the plastic holder... .
Daniel... . thought of duct tape and tiewraps... . we don't use no baling wire round these here parts. :-laf
E C Jay
"If it moves and it's not supposed to... use duct tape. If it is supposed to move and doesn't... use WD-40"
You guys... ... ... ... ... ...
I can always rest assure that I'll recieve a chuckle from you two... ... ... ... ... . Tugboat will chime in soon, as he has pretty much secured the market on the use of duct-tape/wire.
GL
I dunno- My right tail light is held on to the bed with electric fence wire (ran out of the HD baling wire) and baling twine (the "good stuff" poly, not sisal that'll rot in the rain). It is even color coordinated- the twine matches the red tailgate; rest of the truck is/was blue. Dont have much duct tape on the rig, though... .....
-DP
GL
I resemble that remark!!
If you can't fix it, Duck it!!
