Ah. 47RH sorry about that was in a hurry at lunch, I'm usually the last to take lunch and the first to get up during these shutdowns...
Maybe someone else will jump in then with a quick fix.....
Yeah not too hip on those I cant seem to find a complete description of all those controls in the manual, found the 95 FSM focuses on a dash mounted switch, not sure how much a differs from a 94. Had to piece together a bunch of stuff for the below info..... as always disregard if way off base here...
Dug thru some wiring diagrams there are some circuits dealing with the OD.
Could it be an open circuit from the PCM 55 to the trans 3 pin plug, or that hot lt green/bk wire is not hot at the trans, or the switch signal is not changing state to pin 10 of the PCM?
PCM 10 OR/WT is the dash switch thing if you happen to have one.
On the trans Pin 2 LT Grn/bk should be hot, the other two are controlled from the PCM.
PCM 55 BRN is the Trans OD solenoid to pin 1 on the trans. It discussed in the Diesel section 14, it monitors engine rpm and vehicle speed verses TPS voltage, also needed are various inputs from the module timer.... but of course can't just list those inputs to save some time...
PCM 54 OR/BK is TCC Lock. Trans pin 3
TPS was at PCM Pin 22, maybe check it at the PCM? It says need DRB tool, but maybe you can see if there is an harness issue from TPS to PCM? Think Pin 6 was involved in that TPS deal. And the signal B- ref.
Does it have that switch and does the light work when you cycle it?
Could not really find the relationship in the wire diagrams and maybe it was TCC lock up related but the brake switch was brought up in a few very TDR old posts I dug thru.
Was way off on that temp sensor comment above it's like 11k-13k at 68F, 9k-10k at 77, less than 1340ohms with engine warm... learn something new, warmer is lower ohms, colder is higher (kohm)
This was the no 3-4 shift table in the 95 book...
