I have a 2k 2500 4X4 with 72k miles and need to check/replace the rear brakes. I'm getting the truck ready for winter, new hoses, serp. belt, antifreeze flush, already did the front pads, now the rear brakes. Pulled the rear wheels and noticed the drums don't just pull off. Someone said I had to pull the axles and then the drums will remove? :--) If this is true then I might as well change the bearings and seals while it's all apart. The parking brake is not holding well any more so I also got a rebuild kit. I searched the archives and FAQ's for info on rear brake disassembly but came up empty. Can someone provide me with this procedure or stear me in the right direction?
Much appreciated!! Oo.
John
John
