There is a huge difference between the 4bt 3. 3 model and the 4bt 3. 9 series engine. The blocks rear bolt pattern is different on the 3. 3 engine from the shared bolt pattern of the 3. 9 and 5. 9 b series engines.
If you go witht the 3. 9 4bt, it will be a bolt up easy connection for the nv-4500 Dodge bellhousing, clutch and transmission. later year wranglers have hydraulic clutches, so you can build an adapter line to merge the jeep master to the Dodge slave, then you just need to bleed it out and call it done. (easier said than done with the dodge slave as many will tell you, but it is a good solid setup when the air is out of it).
I am looking to build an adapter plates for the 3. 3 that will utilize the dodge bellhousing and another for the p-30 setup that Cummins designed for the 3. 9 4bt. I posted in another thread that I have a scanned image of the bellhousing adapter so the job is 1/2 way there. Kenny at Autoworld already has a prototype bellhousing water jetted out of OSB partially completed, we just need to push him to finish it, or else I will do the design myself with the parts we copied from my 4bt GM adapters I left with him last spring to get this ball rolling.
Let me know if the interest is there for the 3. 3 and I will follow through with it. It isn't worth it for me to do just 1 or 2 so I am not really pushing on with it currently, in the future when I am ready for it myself, I will get more motivated. I set this thread for alerts to my email so I will keep looking for interest here. Don't PM me, just post back here as I think we need a public recorded of the interest on this, if its to justify the work to others I am in contact with on it. I can then print the thread out to show neccesary people that I'm not just wasting their time.
Let me know, I think its a big potential for off road toys and related applications with Jeeps. Just remember, no Tier 2 DOT legal versions of the 3. 3 are available, (yet).
