Another possibility is a compression leak if the injectors have been recently replaced or R&Red (Removed and Reinstalled). Look at your dust cover seals on the retaining nuts. Do they look fairly new, or are they old and dry rotted?
Back to Greenleaf's post- good one about the air and fuel leak :-laf. Look for soot around the exhaust outlet around where the manifold attaches to the head. ALso, is there a chuffing sound, or a bit of a lope? If so, you may have a bad injector(s). If not, it could be an exhaust leak. Not real bad, but not real good, either. ALso, contrary to popular belief, I have never had any luck finding a bad injector by cracking the lines loose and listening to the engine for a change. By the time you get to that point, you need a new set of injectors anyway.
Welcome to the TDR. The best $35 you will spend this year. Go to user control panel in the Discusion Forums drop down menu, and when at your UCP, you will have an option to edit signature. FIll out the year, drive, transmission, miles, whatever else you think may be pertinent.
Daniel
