Engine/Transmission (1998.5 - 2002) Need Help - - - - engine defueling
Engine/Transmission (1998.5 - 2002) Rasp pump leaking ??
Over the past few months I've had a problem with the boost just falling to zero, then coming right back. It's like turning the ignition off and on. I've changed the MAP sensor (twice) , changed the TSP from another engine, cleaned all of the grounds, changed the cam position sensor (that cured it for two days). It started it again yesterday - - - - all I could think of was to pull over and dis-connect both grounds, and re-set the throttle position sensor after waiting about 15 minutes. It worked! Now it's running fine again. We're pulling 30 ft. trailers for FEMA 8 to 12 hours a day, and need to keep going. Anybody expierience anything like this - - - - got any solutions ????
2001 3500 QC Sport 4x4 auto, AFE, Edge comp, 4" DPP, ISSPRO guages (4)
