On the way home, I'm running in 4th gear about 40 mph and the truck felt like it slipped out of gear. The check engine light came on. All gauges read fine, but the truck starts to cut at around 1100-1150 RPM. I take it through the gears to maintain some reasonable semblence of speed and safely limp to the house.
In all gears (1-5) at that RPM, the engine acts as though it is de-fueling OR not getting fuel. Filter is new, I fueled up at the same place as always.
Outside of fuel, what are some possibilites. I was able to bump the lift pump. It is running.
I have an Edge EZ box on and a spare lift pump. I'm thinnking about starting there first.
Any suggestions on what else to look at.
I don't have any codes to feed any of you.
Thanks in advance.
Thanks in advance.
