In process of mounting a fuel pump on the frame rail. The wire to power it is in the This terminal measures roughly .27mm x 2.7mm and accepts a male spade measuring 2.5mm-2.8mm. existing fuel tank harness connector but I need to run a wire to meet up with it at the connector under the cab, rear of front left fender. The opposing cavity is blank. I have to believe this has been done before. I'm having trouble properly identifying the electrical terminal needed. Online search lead me to a locked, 9 year old thread here that mentions the connector under the cab. I need the female terminal as pictured. The rest I think I have covered, Thanks, Tim
