CBari
I Have A 4 Horse Lq Trailer That Has 2 7200# Axles And 16 In Tires It Came From The Factory With 235 X 85 R16 Load Range E. They Were Ok Till The Side Walls Became Weak. Then They Went To Wearing Pretty Fast.
I HAVE A Couple Of Friends That Are Running Goodyear Unisteel G614 Rst Which Are A Load Range Of G And They Look Good After 2 Years Of Use.
One Problem I See Is That My Rims Are Only Rated To 80psi So If I Go With Load Range G I Can Only Run 80psi. Which I Guess Is Ok Since Thats What My Friends Are Doing. My Biggest Reserve On Running The Goodyears Is How Poor They Have Held Up On My Trucks In The Past.
I Guess I Have Just Become A Michelin Man Over The Years As I Have Always Had Excellent Wear Out Them. But I Can't Seem To Find Any Thing Else In That Size With A Heavier Load Range.
Do Any You Have Any Better Suggestions That The Goodyears???
