Just added sport head lights to my '99, and found that the inboard low beam was not used. Since comapny requires Day time running lights, I came up with a way to power the inboard low beams only. Got it hooked up and everything works as I wanted it to, now I would like to decrease the intensity of only the inboard lights by about 40%. The load is 55 watts per bulb,and I need to know if a resistor in line on the negative feed will work and what value resistor I will need, or is there a better way? I can use one or two resistors, whichever is more practical.
Thanks for your help, Denny
